It is currently Sat Sep 13, 2025 1:00 pm
PostPosted: Sun Jun 05, 2022 4:22 pm
First name: Aaron
The title should actually read “comments and feedback Wanted.”
I’m finally getting around to doing something I’ve been meaning to do. I figured if I wait until I’m ready, I’ll never be ready.
Here’s the pilot, and naturally more to come. I plan on making it shorter (I think this was way too long), but I’ve had good feedback on the format, so far. And I’m gonna take my time, so this is not a “view right now” thing.
Comments, feedback (and subscriptions) welcome. . . ;)
https://youtu.be/iWnZirA8w_0
[youtube]http://youtu.be/iWnZirA8w_0[/youtube]
These users thanked the author Aaron O for the post: bcombs510 (Tue Jun 07, 2022 8:59 am)
PostPosted: Fri Aug 26, 2022 3:53 pm
First name: Colleen
Last Name: McTigue
City: St. Catharines
Looks good! I’m building a guitar right now, but I acquired a number of ukulele tops (spruce) from a well-known wood dealer who’s no longer in business ((he harvested the trees himself), so I’m interested in learning how to make ukuleles. I made a violin a number of years ago (first instrument build). I gather that Koa is the traditional wood used for ukes, what are some other woods that work?
PostPosted: Sat Aug 27, 2022 4:56 am
Last Name: Reed
City: Stowmarket
State: Suffolk
Zip/Postal Code: IP14 2EX
Country: UK
Koa and mahogany have been used for over a century.
But modern builders use many different woods. I've also built with yew, cedar, cherry, maple, walnut, spruce and oak - they all work for tops as well.
If you pair a softwood top with a different species for back and sides you have loads more choices.
PostPosted: Sun Sep 11, 2022 4:59 am
First name: Aaron
I’ve gravitated to this for a number of years.
PostPosted: Sat Nov 12, 2022 8:25 pm
First name: Aaron
Just in case, I’ve made some progress on the video build, here’s the next sequence.
Thicknessing top/back/sides
http://youtu.be/yU6foilBkTw
Pre-tapering sides and making a side template.
https://youtu.be/KJISaNigQpM
Bending sides in 2 minutes.
https://youtu.be/VK-O--PUx6g
Gluing neck and tail blocks.
https://youtu.be/HCIK7GeJYT0
These users thanked the author Aaron O for the post: bcombs510 (Wed Nov 30, 2022 12:54 pm)
PostPosted: Tue Jan 24, 2023 2:13 am
First name: Aaron
Driving the bus
https://youtu.be/5yC_JI27nTU
Installing Reverse Kerfed Linings
https://youtu.be/JmYYdlwmw-Q
Brace specs and Template layout
https://youtu.be/oMV1UJ_qnDU
Cutting Rosette channel, brace layout, Optical Center Punch
https://youtu.be/926EfsE6P7w
These users thanked the author Aaron O for the post: bcombs510 (Wed Jan 25, 2023 8:25 pm)
PostPosted: Wed Mar 01, 2023 1:45 pm
First name: Aaron
Carving back braces, plane & chisel.
https://youtu.be/cMHo-ASeckE
Fitting back to sides, notching linings to tuck braces.
https://youtu.be/MmsXY9UAZcQ
These users thanked the author Aaron O for the post: bcombs510 (Wed Mar 01, 2023 8:34 pm)
PostPosted: Thu Mar 09, 2023 5:39 am
First name: Aaron
Gluing back to sides, Hide Glue & Cam Clamps.
https://youtu.be/bGqxqlBAFbk
Cutting Soundhole, Circle cutting jig.
https://youtu.be/U0gGZ_rS8Kk
Gluing Top Bracing, Hide Glue and Vacuum Pressing.
https://youtu.be/ZdC-nXrHTpE
These users thanked the author Aaron O for the post: bcombs510 (Thu Mar 09, 2023 7:29 am)
PostPosted: Thu Mar 09, 2023 12:55 pm
Hi Aaron, thanks for the videos! Looks like your hide glue joints don't get fully clamped for 2 or even 3 minutes, it doesn't gel and become a problem?
PostPosted: Thu Mar 09, 2023 4:37 pm
First name: Aaron
As long as it doesn't move, the hand pressure and slight rub is good enough. In theory, I'd argue I could rub joint all the top braces, but I don't. As for the back to the side joint, my main concern is the heel and tail blocks. Once I rout for bindings, very little is left on the rest of the joint, but no issues so far.
Wait until you see the binding installation, with hide glue.
And thanks for watching!
These users thanked the author Aaron O for the post: Pmaj7 (Fri Mar 10, 2023 1:39 am)
PostPosted: Sun Mar 12, 2023 8:01 pm
First name: Aaron
Hand carving top braces. This one is long, but you can fast forward without missing much.
https://youtu.be/GnVAixxzkpQ
These users thanked the author Aaron O for the post: kfish (Sat Aug 03, 2024 6:11 am)
PostPosted: Mon Mar 13, 2023 12:53 am
The side to top/back joint will be gone, but the lining joint will still all be there. I suppose once you route for binding you could see pretty clearly if you have a thick glue line or not.
These users thanked the author Pmaj7 for the post: Aaron O (Mon Mar 13, 2023 11:39 am)
PostPosted: Mon Mar 13, 2023 4:05 am
First name: Aaron
Very true regarding the remaining lining. For conversation, once I started adding in purfling to the top, I failed to adjust for thicker linings, but, it’s only .030 so not that much of a difference, still enough lining left.
Good eye on the video, and I think I’ll mention this when I glue the top.
PostPosted: Sat Mar 18, 2023 11:27 pm
First name: Aaron
And naturally, I forgot to mention anything about hhg glue timing when I closed the box.
I got so wrapped up in the spreaders. . .
https://youtu.be/yOXHbc7ENXA
But, I do mention it here when I remove the box from the form, mixed in with discussing the form, and spreaders again.
https://youtu.be/8HDnphWdhmY
